Will my £30 McAlistair tile cutter cut 10mm porcelain tiles?
View the thread, titled "Will my £30 McAlistair tile cutter cut 10mm porcelain tiles?" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
Depends on several things grade of porcelain tile what cuts you want to do small strips or intricate better with wet cutter.
Decent porcelain snap cutter eg rubi probably more money than you want to spend.
Reply to the thread, titled "Will my £30 McAlistair tile cutter cut 10mm porcelain tiles?" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
daveok77,
ShaunCorbs,
