Will new pipework airlock?
View the thread, titled "Will new pipework airlock?" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
djboyd
Hi
I hope someone can help me out with new central heating pipework I have installed in a new extention - 5 radiators fed by 22mm from existing house stepped down to 15mm for each rad (or two). However, the existing house concrete floor is not level meaning the pipes slope upward to the point where they join the new build, where they then fall slightly to the drain points and rads. The concrete floor has 2" battons then flooring so there is not enough room to offset the floor uneveness (is that a word?!). Is this likely to cause an airlock, it is a standard gravity fed system?
Thanks for any advice.
Thanks for the replies - I did try a search, but I thought my airlock situation was unique! Good to know it will not be a major issue, the alternative is to get the sds out and chase a long channel out the concrete. I am thinking it will make sense to branch a radiator off at the high point to take the air to the rad - is this right?
Thanks again
Reply to the thread, titled "Will new pipework airlock?" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
djboyd,
fuzzy,
