Wiring s plan from old set up y plan...?
View the thread, titled "Wiring s plan from old set up y plan...?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi all, so things are coming on now at last!
New 250 cylinder in loft all pretty much plumbed in.
F+E tank binned off, new ups pump, 2 new zone valves imstalled...
Now im up to wiring up, have done the immersion, so we have hot water, ive wired in the dual stat. I have me head roughly into what i think is correct...
Last night when i was pressing the advance on the controller, noet was happening....no red light to indicate and no boiler fire....
i did see when i moved the contoller, there are some jumper links on the back of the unit...do i need to move these when going from y to s paln??
Time for a rewire and start from scratch bell the existing cables out to see what you’ve got down stairs and adjust in the box to match
Reply to the thread, titled "Wiring s plan from old set up y plan...?" which is posted in UK Plumbers Forums on Plumbers Forums.
Notagainpike,
Notagainpike,
