....Worcester ea....
View the thread, titled "....Worcester ea...." which is posted in UK Plumbers Forums on UK Plumbers Forums.
ShaunCorbs
Super Moderator
Staff member
S. Mod
Subscribed
any ideas
Worcester 34cdi classic newer type
Spot on burn 9.8 and 66ppm
Gas rate 33kw
Elec been changed
Going back Tom to check gas pressure gov
Check the condense trap mate. I had one doing this where the white small bore pipe inside was kinked and not working correctly.
Done already that was shitty don’t think it’s been serviced tbh well not a decent one drive by more like
Are they awkward to get to?
TBH very easy hardest part is getting the gas pipe out the bottom of the fan undo off gas valve also
Then undo the wires fan etc
Then two 10mm hex bolts at the top of the fan connecting onto the top burner
Remove fan and there’s your bearning plate left in
Only goes in one way 3 prongs etc
Yep common fault on these. The pencil trick followed by adjusting the fan overrun and fan startup rate stops it from recurring.
It's condensation forming on them normally. Adjusting the fan speed and overrun dries it out after use.
Process is as follows to prevent those nuisance recalls for ya.
Hold the spanner button until display changes (10 seconds) and shows 1a.
Release button. Use the eco button to navigate to "5b".
Press the chimney sweep button once. It will. Now glow orange and display current setting for that parameter (fan overrun).
Change this parameter to "18" (180 second fan overrun) using the "eco" button.
Press and hold chimney sweep button until display shows "[ ]"
Now hold both the "eco" button and the briefcase symbol button simultaneously and hold until displays shows "8A".
Press the "eco" button to navigate to parameter "9d"
Change the parameter fan (start fan speed) using the eco button until it reads 55.
Now press the spanner button once to exit service levels.
Hopefully that's clear and helpful.
Reply to the thread, titled "....Worcester ea...." which is posted in UK Plumbers Forums on Plumbers Forums.
ShaunCorbs,
Mastermixlee,
