Popped out to an Ri today that had back filled through the condense, there was an outside overflow pipe that should have saved the boiler but it was blocked with moss!!! It connects to the outside down pipe which is full of leaves etc!
I took the boiler apart & dried water from the fan housing, burner, baffle & even the gas valve was full of water :/ luckily the boiler was off at the time & did not try to run with water in it as the lady spotted it gurgling back into the boiler. Got everything nice & dry & put it all back together, the boiler fan starts at normal speed but then ramps up to crazy speed for a 12 Ri & then the blue light just flashes on & off relatively fast with no attempt to open the gas valve or start ignition sequence.
Im popping back with a new fan on Monday morning as I'm guessing it has to be the pcb damaged in the fan, I'm thinking if taking a gas valve too but hoping it will be okay? Anyone had a similar job & revived a previously wet gas valve? All the electrics stayed dry in the valve & no water passed thought the valve back into pipework luckily!
