Hello, bit of a noob question but would someone be able to help me to understand the pipes coming off our boiler. It's a Grant oil combi boiler, and where the pipes come in is in a room at the front of the house. I am about to box them in but I really wanted to understand what the various pipes supply.
There's the larger 22mm pipes which go upstairs ( I assume to the bathroom) and the smaller 15mm pipes that I'm guessing is the rads/heating? The stopcock I can at least understand 😀 I'm not sure why those two pipes break off to the left, I had assumed they were rads as well but I'm really not sure.
I should mention that there used to be an old oil boiler inside the house (hence the undecorated wall) but we had a new one fitted recently and it was moved outside. So the pipework was from that install and modified by the plumber/engineer.
Many thanks in advance.
