Discuss 2 inch Copper Waste Pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
jaydebruyne
Last year the 2 inch copper pipe had a split in it so I cut it off and replaced it with plastic and joined it back to the 2 inch copper with a universal compression fitting.
The last part of the pipe has now split so my options are:
Cut the elbow off and extend the plastic to there - but I'll only have about 3/4 inch to connect to
Or cut off the elbow and blank it off, open a new hole with a strap and connect it with plastic.
My questions are:
How do I know if the 4inch stack laying horizontal is iron or asbestos???
What of the two options would you choose?
I'm leaning towards a strap boss and a new hole but I've got little room for a drill as this is all between floors...
It's cast also I would replace it from the female iron in the cast stack
Can you not unscrewthat iron out of the boss? Then pop in a mcalpine iron to compression?
I don't think this will fit - the pipe is 2 inch so the that female iron must be slightly bigger or 2 inch also. That mcalpine is inch an half and the male thread is inch an half also I think - I don't think they do a 2 inch - are there bushings available? Just done a search but came up with nada
have a look at mcalpine t12f reducer
none of those are 2 inch though - that female iron looks like 2 inch to me - or am I missing something (it's not unheard of haha)
UPDATE - the T12E is 2" to 1.5" ;)
I'm not convinced the female iron is 2 inch though - what do you guys think?
Polypipe Terrain 213.2
2"BSP Male Iron x 50mm S/W Socket.
As it looks tight you could go for the 217.2 which in a Spigot rather than a Socket then stick a 45 straight on it (201.2.135).
OMG I still remember all the codes how sad.
Nothing sad about that - I wish I had a memory like yours ;)
just be careful when putting old threads esp caste to plastic male irons
As we get older our memory gets a bit more selective. You can vividly remember things from years ago but can't remember where you were yesterday
I think it's the skirt we mostly remember!
Reply to 2 inch Copper Waste Pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
small hole in plastic waste pipe which is the better fix ? Hi there need some advice please, i have drilled a small hole in the plastic waste pipe...
Think I know the answer is no but asking just in case. I have a solvent weld bathroom waste with lots of connectors in it that disappears into...
In my last posting, I requested assistance in exchanging a waste that had been fitted using silicone, without actually removing the basin. Mission...
Hi folks I need to fit a kitchen monobloc tap temporarily. A new sink unit will be going in soon so this will just be a stop gap. The current...
