Discuss 40mm pipe to 50mm internal diameter boss in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Boss Adaptor
I don't know if such a thing just doesn't exist, but I am looking for a boss adaptor for a 40mm solvent pipe to fit a boss with 50mm internal diameter?
2” to 11/2 reducer eg 50mm to 40mm
Hi Shaun, so I brought a reducer from screwfix which I understood you were advising, however the outer part is the same diameter as the pipe I am trying to fit so doesn't fit in it.
I measured the outside of the boss, which is 55/56mm external diameter. I've included a photo of the boss in question now.
Link to said reducer ?
Have you tried a 40mm coupling ?
Reply to 40mm pipe to 50mm internal diameter boss in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I am in process of replacing an existing sink with a new stainless steel one. The existing tap is plumbed directly to copper which means that it is earthed. The new tap will use flexible tails and so will not be earth bonded. My initial search for information suggests that there is no legal...
