Discuss 40mm pipe to 50mm internal diameter boss in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
B
Boss Adaptor
I don't know if such a thing just doesn't exist, but I am looking for a boss adaptor for a 40mm solvent pipe to fit a boss with 50mm internal diameter?
2” to 11/2 reducer eg 50mm to 40mm
Hi Shaun, so I brought a reducer from screwfix which I understood you were advising, however the outer part is the same diameter as the pipe I am trying to fit so doesn't fit in it.
I measured the outside of the boss, which is 55/56mm external diameter. I've included a photo of the boss in question now.
Link to said reducer ?
Have you tried a 40mm coupling ?
Reply to 40mm pipe to 50mm internal diameter boss in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down...
I am in process of replacing an existing sink with a new stainless steel one. The existing tap is plumbed directly to copper which means that it...
