Discuss A strange dripping tap problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
RingRing
Hello?
Hi you came round and re-washered my tap the other day.
Ok.
Well it's not leaking anymore but I've since been chatting to plumbers online and they say I should get you back to re-seat it anyway.
*click*
T&C's on said plumber's website:-
The passing of water is a natural process, and whereas every effort will be made to prevent the passing of water when taps are re-washered by us, no guarantee can be given that said tap will be drip-free.
For anyone experiencing problems with taps dripping after they have been repaired by us, we recommend turning off the water at the stopcock after each usage of the tap, followed by draining the pipe leading to the tap in question, which should render said tap drip-free.
Further assistance can be sought through our Customer Services Department – please ask for head of drips.
Later..............
ring... ring...
Customer: “Hello, it’s about my dripping tap!”
Plumber: “Oh no! Don’t tell me you’re still dripping on about your flaming taps!”
Customer: “I don’t like your attitude – I’ve had a basin full!”
Plumber: “Oh turn it off will you!”
Customer: “You promised me my taps would be leak free!”
Plumber: “Yeah, well, I haven’t charged you for the leaks, have I?”
Customer: “But my tap is still passing water!”
Plumber: “So am I at the moment, I’m on hands-free!”
Customer: “This dripping is driving me mad!”
Plumber: “Tell me about it!”
Customer: “Surely you can pull something out of the bag!”
Plumber: “Don’t you bring my wife into this!”
Customer: “I’ve been told my seat needs cutting”!
Plumber: “Probably too many burgers!”
Customer: “Don’t change the subject, my tap’s still running!”
Plumber: “So is the old nag I backed in the 3.30, but you don’t hear me moaning about it!”
Customer: “I’m lost for words!”
Plumber: “OK, so save on your phone bill!”
[FONT=&amp]Click … brrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr.[/FONT]
I have had the problem for years and always assumed it was the washer, but the workaround (turn off the other tap) always worked so I didn't bother.
The plumber spent 2 days installing new boiler etc, but said he would look at the tap before he left, especially as the hot tap would now be at mains pressure for the first time.
He was in a rush to leave, as the boiler took longer than he thought. It only took a few minutes to change the washers, and he TOLD me the seats were OK (but he was in a rush so may have said this even if they weren't).
It seemed OK when I tried the taps, but just after he left the symptoms started again, just like before.
He didn't charge for doing the washers (I was paying him £2000 anyway) so I would not expect him to come back just for this, but if the boiler goes wrong I will ask him to have another look when he comes.
Or have a go yourself maybe?
Draper 12701 Tap Reseating Tool (17, 19 and 25 mm): Amazon.co.uk: DIY & Tools
( Sorry for lack of replies - on Hol )
Question , Does the " Open the other tap trick " work with any other tap in house ,
Thinking of a pressure build up ! Finding its way out at weakest point
( Do you have a water meter fitted )
I really don't get this reseating malarky! :uhoh2:
Been doing reactive for years and never had to reseat one single tap.
Had a blob of solder stuck to the seating once, flicked it off with a screwy, rewashered, done! :smilewinkgrin:
( sorry for lack of replies - on hol )
question , does the " open the other tap trick " work with any other tap in house ,
thinking of a pressure build up ! Finding its way out at weakest point
( do you have a water meter fitted )
yes to the 2nd bit.
It only applies to the kitchen mixer tap, but (as previously said) my partner has same problem in her house, but the other way around.
So what you're saying is...........
She can't bear to be with you fulltime?
yes to the 2nd bit.
She was just a friend at the start of the thread and now she's your partner - congratulations :hurray:
maybe buy a place together where all the taps work ?
Reply to A strange dripping tap problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a Bristan Manhattan mixer tap in the kitchen. Five years ago, it started to drip. I replaced the valve in the cold water side and the...
I have a kitchen mixer tap with quarter turn levers and the cold side started dripping. I took out the ceramic valve and replaced it with one from...
Hello all, first time poster so if there is any additional information I can provide that may help, please let me know. Our kitchen mixer tap has...
This is probably obvious but I want to replace the cartridge to stop dripping. I have done similar before but I cannot work out how to remove the...
I have been trying to turn off my outside tap for winter. When I turn the valve under the kitchen sink, it fails to stop the outside tap from...
