Discuss Added Fernox for 2 days & Drained Flushed in the Plumbing Jobs | The Job-board area at PlumbersForums.net
O
Oneilly
Hi guys looking for a little advice. 14 year old house, suspect the system has had little maintenance.
I added fernox cleaner left for 2 days then drained & flushed, just checked next day and the water is dirty again?
Should I repeat exercise ?
If still dirty ,you do not say which fernox cleaner you are using,but yes,I would leave longer than two days,should run 48 days hot,which if you have on 8 hours a day is at least 5 or six days
Also many make the mistake of trying to flush through a normal system drain cock,this is no good,fit a good full bore drain point,to allow system to be flushed out correctly
Keep a eye on all fittings for leaks and take your time when flushing out system
imho
i agree fully with puddle,2 days not enough if very sludged up
I always planned to leave for a week and then got a blocked Rad and found myself draining down, silly me, oh well off to plumb centre again lol
what boiler is it? sentinel x800 is good stuff but aggressive
Before you add some more chemical ,flush out as mush sludge/black water ect as possible from the system,chemical will be more effective then
Gas Man a 14 year old ideal Classic ff260.
Puddle, thanks yes I have given it a good flush, lots of rubbish came out.
x 800 should be fine but read the instructions it is good stuff
with x800 its min 2 hours but i think max is a week it will say on the bottle i only use it as a last resort it kills aluminium boilers ,but it fully removes the crud its potent stuff!
no probs oneilly hope this sorts it,but puddles advice will help as well
Reply to Added Fernox for 2 days & Drained Flushed in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All This is following on from thread I made a few days ago but can't seem to find I'm in a bit of a bind with my CH design where I want to...
Hi I have recently bought a house which is 17 years old. There was a small leak from one of the radiators So I took the pipe off and drained the...
When we moved into our house in 2016, the electric water heater popped loudly when heating. After awhile, I researched and realized that it was...
I have flushed a CH system removed each Rad and removed any residue of black sludge filled the system up and treated with inhibitor. However after...
Hello everyone, Baxi Ecoblue System boiler which was recently serviced just before Christmas. There has since been a constant but slow drip...
