Discuss Advice on fitting Nest or Hive Controllers. in the Central Heating Forum area at PlumbersForums.net
T
Terry Savage
I currently have normal programme controls with thermostat for 3 zones (3 floors). The main controls are located together on the ground floor and individual thermostat controls on the 2 other floors.
Would either a Nest system or Hive be adaptable, if so any advice on which would be best & how to configure it. Thanks, Terry
Hi Terry, depending how you heat your hot water you’ll need a 2-3 channel programmer with additional receivers for the 3rd zone. For example if you went down the Nest route, you’d need 3 heatlink and thermostats, whereas Hive would need a multi zone kit and additional receivers.
Reply to Advice on fitting Nest or Hive Controllers. in the Central Heating Forum area at PlumbersForums.net
The left rear floor corner is highest (the shower pan touches/sits on the floor), sloping down diagonally to the front right corner (lowest). The...
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
