Discuss Advice on waste connection for bowl sink in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I need some advice connecting my bowl sink to the waste. There was a Insinkerator installed that I have replaced with basket strainer waste (Viva PP0011).
I need to connect the waste but I find myself going around in circles in regards to selecting the correct parts.
FrankW
Could do with a photo of both from the front to gauge distance apart but I would expect you need one of these.
Could I have a measurement between the 2 basket strainers
https://www.NoLinkingToThis/p/mcalp...PNCniyA76oTmjg-R7y4aAkecEALw_wcB&gclsrc=aw.ds
Mcalpine asc10 and see what fittings you need might just need a elbow
Don’t forget to cap the unused washing machine points with the blue caps if you haven’t already
Reply to Advice on waste connection for bowl sink in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi, grateful for any advice I need to connect a dishwasher waste water outflow pipe 25mm to 50mm waste pipe. Is there a joining piece anyone can...
Hi all, Bit of advice needed. Waste water pipe from bathroom sink came loose last night caused some water damage to ceiling below. My question...
Hi all, grateful for your expertise on the following. DIYer, not pro. Rural property in France Single storey. Septic tank. Late 80s construction...
Hello, I'm installing my first Belfast/butler kitchen sink. It came with the waste and stainless steel drain. To my surprise the kit only has one...
small hole in plastic waste pipe which is the better fix ? Hi there need some advice please, i have drilled a small hole in the plastic waste pipe...
