Discuss Anyone had their appendix removed? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Ten days in hospital after mine taken out. Back at work on light
duties on the Monday following discharge. Another ten days then
back operating caterpillar side layer crane.
Reply to Anyone had their appendix removed? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Size of bathroom 230cm x 210cm Height 230cm Birmingham Area Initial problem Burst pipe underground in bathroom, concrete. Have had this dug up...
I have a wall mounted bathroom tap that leaks. Presumably I need a washer of sorts replaced. I cannot work out which tool I need to remove the...
Hi, I am trying to clean out my Merlyn Truestone slate shower tray waste unit. I cannot see anyway to remove it to clean underneath. I'm stuck...
Hi, Can anyone offer me advice, I’ll try and keep it short! Just cleaned my magma cleanse unit, and it wasn’t too bad since last boiler service 1...
V
Hi all, I'm completely inexperienced at this, but my kitchen taps are ancient, and the water has started dripping. Rather than just change the...
Deleted member 120897
