Discuss Anyone recognise this? in the USA area at PlumbersForums.net
Hi, I have an old and quite long house with a gravity fed system. This item pictured I think is a pump or valve, it’s attached to the 22mm cold feed from attic tank to hot cylinder below. It is wired up to a 3 pin plug and on a timer! It’s not actually plugged in but when I do it just continuously runs? Does anyone know what it’s meant to be doing?
I would agree thats a circulating pump difficulty to tell from pic but is it yellow painted?
If so could be a bronze pump though if it is on tank feed difficult to know why!
It would make dense for a Long House to have secondary circulation.
The return pipe must be Tee'd into the feed from CWS tank just above the pump.
Thanks for reply’s everyone, you are correct it’s the hot feed not cold. And yes a circulating pump would make sense as the house is quite long! Thanks again.
Reply to Anyone recognise this? in the USA area at PlumbersForums.net
Hello, and thanks for taking the time to read. I'm trying to work out if the idea I have is practical? The water pressure in my newly renovated...
Hi, I'm new to the forum and just some background on myself. I have 4 years experience as a plumber but haven't worked in the trade in 15 years. I...
Hi all, this is my first post, so hello to everyone! We have a tap in our kitchen which has started leaking from the joystick cartridge - (though...
3K
Hi. I was Wondering if anyone can help I had a huge leak under my kitchen sink And where the bowl sink kit goes onto the outside pipe/waste I...
2K
