DarloCol
Anyone with knowledge of older Baxi boilers?
Last week, had a MagnaClean fitted to my 10 year-old Baxi Solo 2 60 SR which serves a Y-plan heating system (pumped to rads, but gravity DHW).
Since then, the Overheat Cut-off keeps tripping. When fitting the Magna Clean, it seems the engineer removed something called an 'adapter tee with injector washer' that the Baxi Solo manual says should be used in combined pump/gravity systems such as mine. The manual states: "Failure to fit the injector washer will result in reverse circulation in the DHW circuit".
The engineer says this is not the cause of the problem, and probably the heat exchanger is all furred up.
He says the injector washer merely inhibits circulation and the only effect of removing it will be warm radiators when just using the DHW. I'm not convinced. The manual refers to reverse circulation IN the DHW circuit, not from it.
Any thoughts please, before I contemplate some kind of chemical clean to see if that resolves the overheating?
Cheers
Cheers
