Discuss bending 28mm tube with spring in the Plumbing Jobs | The Job-board area at PlumbersForums.net
mutley racers
Subscribed
Is the best way to do this by annealing tube first and cooling with water before insertion of spring and bending?
Coming from a guy who does not wear knee pads.
Come to think of it, that's probably why you don't wear pads a. Not knackered from using springs
Anneal it first. Its usual to fill tube with sand.
Anneal it till it glows a nice red
The pipe these days is harder than it once was so you will probably have to anneal it. I've never bent 1" pipe with a spring for over 30 years. Fk that.
Always used a tripod bending machine up to 1"1/2. Wish I had never sold it on, but came off the tools years ago and would never use it, until now, as I have a bit of 28mm to install. OH 'well second best have to buy the expensive fittings.
Fill it with sand, is this so it doesn't kink or something?
Different bending method. If you have a spring heat the pipe until cherry red and cool it. Stick the spring in and pulll your bend. Spend 10 minutes rubbing the heat marks off the pipe if you can see it.
Save up for a 2nd hand bending machine. Much easier and better bends than a hand bender.
Hilmor Irwin CM35 pipe tube conduit bender vice | eBay
HEAVY DUTY RECORD PIPE / TUBE BENDER c/w 15mm,22mm, 28mm & 35mm FORMERS & GUIDES | eBay
What do you think we did before bending machine, sand load it yes, you would then need oxy acetylene to heat it up sand loaded and bend it on a bench, but like you say spring bend is OK, anneal it well till cherry red, you will need a big torch for 28mm copper and I mean big, about 25mm dia at least, cool it down quickly with water, I hope you are not trying a full 90 bend just offsets, if you want tight offsets keep the annealing to a short length or you will end up with long offsets. The copper will work harden fast on the first pull over your knee, you may need to anneal it again to bend further, make sure the spring is a good fit, if its going to ripple 28mm will certainly ripple. If you try and anneal 28mm with a standard Rothenberg bottle nozzle forget it, also anneal it indoors and wind outside won't cool it and you won't get the tube cherry red and in sunlight you won't know if it's cherry red or not. Sand loading any pipe cooper or steel is not for the untrained. If you fancy shelling out £1000 the Rems Curvo bends 28mm like shelling peas
Reply to bending 28mm tube with spring in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have just installed a combination all in one WC/small basin…. Out of the fill valve there is a small tube which emits a lot of water...
Evening All, We've just moved into gas boilers (after years doing gas) and are currently tooling up. On our first install we had problems bending...
I had an outside tap fitted by a professional plumber last autumn. During the recent cold weather the feed pipe under the kitchen sink froze and...
Hi, Short version: I have about 4" of pipe sticking out of a concrete floor in a cupboard. It makes a 45-degree bend as it exists (bent, not with...
Hi All, Looking for a bit of advice on the best way to pipe this. - 24kW Worcester regular boiler in kitchen, approx. 9 years old - unvented...
