Discuss bending 28mm tube with spring in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Always used a tripod bending machine up to 1"1/2. Wish I had never sold it on, but came off the tools years ago and would never use it, until now, as I have a bit of 28mm to install. OH 'well second best have to buy the expensive fittings.
Solder ring fittings cheap as oot at screwfix if u just need. Few? Or buy a hilmore off eBay/ loads of sparks selling theirs cheap then buy new guide and form , sell it again?
With the additives in copper pipe now bending 22mm is hard work on a manual bender never mind 28mm and springs, assume you must have your reasons.
Managed a massive offset by hand on 28mm before. 3m length in to scaffy tube bend tiny amount then pull out of tube a tiny bit and bend some more...... Works but its rough!
When i was serving my time we had an 1 1/4" spring. You stand on the pipe and pull it.
Well I bought a spring any way so shall give it a go. It is for a gas pipe so the less fittings the better.
Thanks guys. I shall see how it goes. Hilmor benders are expensive. Don't think my wife will let me buy one:-(
Reply to bending 28mm tube with spring in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have just installed a combination all in one WC/small basin…. Out of the fill valve there is a small tube which emits a lot of water...
Evening All, We've just moved into gas boilers (after years doing gas) and are currently tooling up. On our first install we had problems bending...
I had an outside tap fitted by a professional plumber last autumn. During the recent cold weather the feed pipe under the kitchen sink froze and...
Hi, Short version: I have about 4" of pipe sticking out of a concrete floor in a cupboard. It makes a 45-degree bend as it exists (bent, not with...
Hi All, Looking for a bit of advice on the best way to pipe this. - 24kW Worcester regular boiler in kitchen, approx. 9 years old - unvented...
