Discuss Can't connect cistern inlet connector because of inlet filter in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi.
I think the title says it all really.
I was just lining up pipework and stuff and noticed that the Speedfit 15mm X 1/2 BSP tap connector won't connect to the cistern inlet because the inlet filter protrudes out too far to allow the rubber washer on the connector to sit against the outer edge of the inlet.
Contemplated removing the filter and not replacing, or modifying the end of the filter (cutting of the cross shaped bit). 5his may allow enough room for the connector to push into the inlet sufficiently.
Or have I just bought the wrong tap connector? Haha
Any ideas.
Will the filter fit in the other way around , if it's a different shape on the opposite end.
Looking at the photo in greater magnification it looks like the ends of the filter are designed to compress when the connector is screwed on.
If the filter is in the way, just remove it.
That's what we do.
If the manufacturers cannot make a filter that enables general plumbing fittings to connect to it, then the filter is not fit for purpose.
Are you ever going to call the manufacturer for a warranty replacement of that part?
They would deny it with or without filter installed
Yep or cut it down slightly
Reply to Can't connect cistern inlet connector because of inlet filter in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
  • Locked
First time posting on here and I am after some help and advice on a project I have ongoing at home - a bit cheeky I know but as they say around here ‘Shy bairnes get nowt’! My children (10 and 8 at the time) were lucky enough to be given an above ground 15ft round swimming pool from some...
2K
N
  • Locked
Hi I have always replaced the cistern valve myself. Usually use a torbeck valve. It has always been straight forward and quick. We have a compression elbow joint isolator (15 mm 1/2) just beneath the inlet hole in the cistern. Just enough space to accommodate the screw portion of the inlet...
4K
N
Z
  • Locked
Hi I've just replaced the ball float valve in my side entry toilet cistern but when I've reconnected it there is a leak where the tap connector meets the plastic thread. I'm not sure why. Could it be just that the connector isn't quite straight to the plastic thread of the float valve or does...
7K
  • Locked
Hi, this is probably a really basic thing, but I'm a complete novice. Have connected a wall hung toilet to a Grohe rapid frame system. I'm using the connector supplied to connect cistern output to inlet on toilet. It looks like a tube with 3 rubber flanges on one end - sorry, don't know the...
30K
A
  • Locked
quick one that i cant remember right now and is buggin me. the water inlet connection to the cistern is that a (assuming I need a 90 degree connection from inlet to copper) female elbow (with thread tape) or is it a bent tap connector. simple but cant think right now.
8K
andekoch
A
