Discuss Cracked Mira Flight - what do we buy next? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, we bought a Mira flight tray back in March (it’s been under the bed since then as we ran out of money to finish a second bathroom). We pulled the tray out, peeling the plastic off and it has a hair line crack on one side. Mira won’t do anything about - understandably. But it means that we have to buy a new tray, any tips on what make? We are feeling a little apprehensive about buying another Mira as the most we did to it was move it under the bed to store safely. The size tray we need is 1200 x 900. Any advice would be gratefully received.
did you leave it with the foam edge protectors on ?
Never had a problem with Mira i think you have just been unlucky , if you dont want to go down the Mira route again then have a look at just trays or merlyn I have a quad to do next week looks pretty decent stuff , whatever tray you choose the riser kits if needed are all pony the front and edge trims never fit very well . Best of luck kop
As above, just trays for me.
Avoid the cheaper ones with stick on legs, bloody useless!
I used to use Mira Flight until one split after 14 months of use and they refused to warranty it.
I used to fit mira flight all the time but I have had two crack in the last two years. I am in the middle of replacing one I changed 2 year ago and even put extra leg where the previous one cracked and it just cracked either side where the thin bit is in front of the waste. Think the quality is dwindling....
Reply to Cracked Mira Flight - what do we buy next? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Good morning all. Im just about to install my new shower tray (Mira Flight low) but I’ve noticed some ‘crunchiness’ at a couple of small points...
2K
Okay. So I have a ground floor shop and second floor flat for sale (potentially). No major need to get shot of them, but not a lot of point...
Now sorted... don’t bother reading this stupid long post. Hi, I’ve got a bit of a head scratcher here and wondered what you guys would make of...
2K
Sharp Point
  • Locked
Just had another idiot (a property developer) who is starting to get funny come payment time. This is despite a detailed written quote being sent...
Ray Stafford
R
F
  • Locked
Ok here goes, any advice greatly appreciated and here’s our story… Basically moved in to new house end Jan and knew it needed new boiler (15...
3K
fletch25
F
