Discuss Drips of Water from Pipe Next to Boiler? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a small pipe (Picture below) just above my boiler that I noticed yesterday has had a few drips of water come out of it, it was a fairly rainy day so thought it may be related, however thinking about it it may have been dripping for months.
https://i.*********/7M5j6MD.jpg
Searching the internet the suggestions are this is a pipe where pressure is released if the tank upstairs has to much pressure in it?
I read I need to check my pressure gauge but I can not find one, checked boiler, tank upstairs and water tanks in loft.
As I am a complete novice I have no ideal what type of central heating system I have so no idea if I should have a pressure gauge or not, let alone any idea if this should or should not be dripping occasionally.
My home is a new build from 19 years ago, I have a boiler in the kitchen, a hot water tank upstairs and what looks like a big and a small water tank in the loft.
Please could anybody shed some light on what this drip from the pipe could be and what type of central heating system do I have?
Many thanks in advance for any replies.
Martin.
As Riley says its an mt cock, in a very poor state. What you need to realise is that in side is a rubber washer which has perished. So dont fiddle with it
the end has a square post and can be turned but LEAVE alone
esp as its Sunday. If your knowledgeabke and confident tell us what you would do if not call a plumber tomorrow
By the sounds of it, you have a conventional open vented heating system with gravity fed hot water. You will not require a pressure gauge with this type of system. The valve in the picture is as Riley said, a drain off cock. Looking at it, it's been leaking a while, if your not confident yourself, call a plumber to come a change the washer.
Many thanks for these fast and very helpful replies.
I have zero plumbing experience so on your advice I will not touch it and call an expert out.
Is this a costly job or a simple case of changing the drain cock do you think?
It can be really simple but depending how the plumber opts to drain down, it could end up been half a days job if the system airlocks or cold feeds blocked.
As you state you have no choice and servicing the mt cock might well involve a drain down ...I know it looks very small but is a quite important component in the scheme of things .so a ..drain down , replace part, then refill and system bleed takes quite a while...the component costs me about £1.00
centralheatking
No idea thats what it has always been called chking
all fittings have a number as well ..like 15mm connector is a No 1 but then you can get No 64. and so on ...they are in a big book somewhere
Those numbers were, AFAIAA, all preceded by YF, as they were the item numbers from the Yorkshire Fittings catalogue. I still remember most of them, but ask for a No 14 at a merchants and all you will get is a confused stare. Or maybe those numbers were always there,and YF adopted them?
Apart from Kit 32?
Reply to Drips of Water from Pipe Next to Boiler? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
