Discuss Exposed thermastic shower valve 2mm inlet in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I need to replace an exposed thermastatic shower valve with 22mm inlets and centres of 140mm. Any idea where they can be purchased?>
Is this a bar shower ? with 22mm nut at the back ? if so that is a standard size so most bar showers will fit, photo would help.
Reply to Exposed thermastic shower valve 2mm inlet in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
I'm replacing the shower cartridge on my Bristan 1901 Thermostatic Exposed Dual Control Shower (Top Outlet). I have removed the cap and screw but...
AlexTTT
A
Hi everyone. I'm installing a walk in shower, opening into shower will be on right, mixer value on right, but shower head and drain on left. The...
I Think I want a Thermostatic shower valve. Can these be added/installed to an existing shower?
Hi All I had an unvented cylinder fitted about 6 years ago. It only supplies hot water to my shower. I was hoping for a much better flow rate from...
Steveo111
Can anyone please tell me where I might purchase a 90° bend 15mm x 22mm Isolating Valve Thanks and Regards. Hugh
