Discuss Flue terminal not sealed in the Plumbing Jobs | The Job-board area at PlumbersForums.net
TFGplumbing
So I ''at risked'' a boiler last week because the flue terminal is not sealed with cement externally, it is sealed badly internally with silicone.
Land lord is questioning warning notice.. 'can't it just be sealed internally with cement?'
I said no as flue gases could potentially enter the cavity.
Tell me I am not going insane...
Does it have a cowle externally ? If yes it's fine if no your right
That's wrong, ideal would say it's OK if it just had weathering collar. No cement required, baxi wouldn't
So double standards gas safe say must have a collar on the outside and either collar or sealed internal
Don't even start with vaillant, some of their staff don't even know that if their flue ain't sealed inside but is sealed outside, then it's AR!
Ive an email with this on from their technical.
All mi's say to BS 5440, yet it's different horses for courses with some.
I just judge it how I see it, if it's not sealed outside an you can move it easily then AR it.
Carry some fire cement around as a temporary measures
Yea so collar on outside and sealed internal fine, no collar and not sealed outside ar, sealed both ends with approved methods fine
Thanks for your replies guys :D
Its a early 28i Junior.. there's no cowle. The silicone seal internally is so poor you can see day-light.
The reason its not been sealed externally with cement is because its a loft install.. on a gable end & there's a conservatory beneath it; so no hope of getting ladders up to it.
Landlord is getting twitchy because he knows he'd need a scaffold erected just to put some cement in it.
will it always be AR until its cemented externally is basically what i'm asking. thanks
Ir the flue hole is only size of core bit, Worcester are sound with that an cowel.
Take the flue out am fit the cowel on it, an pull it back to Wall an it's sorted.
Or take a pain / sheet out from the conserv
New vaillants are nearly impossible to seal outside, as the collar is fixed.
Yeah I heard that mentioned before... Must be better than the stuff iv ever used lol... Horrible messy stuff anyway
Yep don't get I on your hands doesn't come off for like two weeks
Can't agnst gas safe rules as can crush flue (or so I believe)
Yeah, sealing flues with expanding foam is a no / no isn't it ?
Few years ago they come up with this didn't they ?Nothing ever simple in this job, constant changes.
Yep but think it's the old ncs if everything else is ok
not quite true,if you use a low expansion type and it does largely depend on what the Manufacturer allows,foam is ok,as in everything mi,s dictate what can be used ,Baxi and ideal allow foam
I swear it depends on who picks up the phone, had a load of duo tec's on a new build where builder used foam. I called Baxi who told me its a no no and their engineers won't work on them. Gas Safe said depends on the foam used. Dismantling a conservatory seems extreme, I'd be inclined to seal using long reach nozzle with express cement and correctly seal the inside. Analyse it...happy days!
And all this conversation exists because someone picked the cheapest price again and someone didn't do their job properly.
probably
in my opinion
not sure if the sealing with c&s is a building requirement rather than gas safe or manufacturer which is why replys to this question can be vague
Said it before AR at times is so wishy washy and customers end up so confused why you fail a flue for this reason.
What's the odds of someone having an issue with a fan flued appliance that had internal an external collar but unsealed?
That's not to mention the gases becoming diluted in atmosphere
They should of got rid of at risk if you ask me, it's farcical.
Your appliance isn't safe but you're not letting me isolate it, well at least I've covered my back.
its all rather farcical, only gas engineers care about the classifications, most people dont even know what gas safe is
Seeing this on a daily basis working in landlord flats I have never AR a flue for not being sealed externally.
If I happy flue is secure and preferably cement sealed at least on inside it is just an observation as far as I am concerned.
And expanding foam is just a no no.
Unless MI allows the rubber as a seal then its AR. Easier to cement up than do paperwork unless high up
I went on a Taylor Wimpey new build site where the builder had expanding foam all the flue holes about 90 of them on ideal logics. Phoned up ideal and they said no no no they won't honour any warranty with expanding foam .
Reply to Flue terminal not sealed in the Plumbing Jobs | The Job-board area at PlumbersForums.net
E
Hi all, Apologies if this has been covered elsewhere but I can't find an answer to my questions. I have a back boiler and gas fire which h has...
Had conventional boiler and tanks removed last year and new combi fitted and just recently had it serviced but the guy who did it has given me a...
Hi, I've been having trouble with my boiler leaking for months. We thought we'd fixed it last winter as haven't had any trouble throughout the...
Hello. I'm hoping to get some advice. I moved into a new build house a few years ago. A Firebird Silverpac external oil boiler (kabin pak type)...
Hi, I have just noticed a damp patch around where my boiler flue exits through to outside wall along with a rusty colour around the collar of the...
