Discuss Fortic cylinder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
barronbathrooms
Evening all! Went to look at a bathroom today for one of my landlords. In a ground floor flat direct fortic cylinder about 600m off floor pressure really poor. Is there a way to increase flow rate. Thought about a pump but obviously the tank above is really small so may not be able to cope with demand(bath, whb and sink) anyone any ideas!
Whats incoming mains pressure and flow like? Direct unvented cylinder?
The only way your likely to improve the supply is spend lots of money.
The fly in the ointment is that there us a landlord involved.
Best just fit a triton wall mounted shower pump to appease the tenant.
Changing system not an option(landlord tight as ducks nether region) to be honest don't think incoming was to good 12 lt per min tops.
Suggested shower but still doesn't solve hot water. It's quicker to fill sink by boiling a kettle!
one thing that helps is avoid mixer taps and taps that dont work well on low pressures.
Reply to Fortic cylinder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
I have a viessman vitodens 222F combi storage boiler on the ground floor. It has 100l capacity inbuilt cylinder which is delivered on mains...
Max Hill
M
Background I have a small one-bedroom flat in the roof space in a victorian house. There are three floors below and each floor has a single...
Hi Could I ask for some help with a water flow rate problem. I have good mains water pressure on the ground floor. There is no tank in the loft...
1K
Hi, I have a hot water cylinder which feeds 3 outlets (kitchen sink, basin in bathroom & bathtap) which has never had very good pressure (probably...
1K
Hello, I am renovating a small bathroom in an apartment on the 5th floor. Heating is electric, no gas or oil. I have four (related) questions...
