Discuss Gas isolation valve with test point in the Plumbing Jobs | The Job-board area at PlumbersForums.net
gas tec
Can anyone tell me where I can get a 22mm gas isolation valve with built in test point. It must be full bore.
does it matter if you have to use male irons? (eg can the valve be threaded)
Reply to Gas isolation valve with test point in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can anyone please tell me where I might purchase a 90° bend 15mm x 22mm Isolating Valve Thanks and Regards. Hugh
British Gas servicing the above boiler ramped up the boiler to maximum in the installer menu to do flue gas analysis. They also measured the...
Hello, Is it ok to use a full bore isolation valve to isolate a hot and cold feed to taps or should I use a service restricted bore. I’m thinking...
Hi Anyone know of a pull out kitchen tap that has decent pressure? I have had low pressure from this tap for a number of years and it's not...
Hi Just had a new bathroom installed with a toilet bowl that reaches the back wall. Its has a bottom entry cold feed to the cistern. The fitter...
