Discuss Good example of why we test with appliances connected. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Chalked
Brand new Vaillant system boiler. New build house with inset gas Fire,cooker and boiler. 10mb drop!
last thing I isolated was the boiler.
I shut a vailliant off today as gas was passing through gas valve to burner, only about .30 of a mb per minute but enough that I noticed it
Did a rayburn nouvelle last week, tightness test failed so got my sniffer out and traced the leak to the pipework in the solid floor as they had ducted the pipe and it was coming out of the duct outside :) so serviced the rayburn, then IDed the service pipe and disconnected it at the meter, customer wasnt unduly unhappy, just got their local plumber in to reroute the supply round the house.
Reply to Good example of why we test with appliances connected. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Hi, we have a back combi heater. Whenever the heating comes on it seems to lose pressure within a few hours and I have to refill each morning. The boiler seems to function well, and the pressure only drops with the heating and not the water being on. Ie it started last winter and was then...
I just had a quote for a new boiler install as follows I dont undertand why a 15-60 boiler pump is needed and a 25-100 pump is needed as well I currently have an ideal mexico 2 heat only boiler - It has one DAB pump on the boiler return and a 2 port valve at the flow pipe to allow for heating...
Hi. I recently had a renovation done. My builder installed a new Combi boiler instead of my system boiler. He connected the pipework to the digital pump. He did not inform us that we would need a new processor because we had changed to a Combi and subsequently a valve blew. Should my builders...
I have a Vaillant eco plus 837, year installed 2008. It works well. We have one large zone for the house with 13 rads running off it. We also have an UFH zone in the kitchen. Near the boiler I have 2 port valves which control this part of the system. The boiler has been loosing pressure...
I recently had a new 2023 Vaillant ecoTec plus 630 (30kW) system boiler installed along with a Low Loss Header (LLH) in my house. I have 21 rads in the house and a room with UFH. The LLH was introduced as I was finding (before the LLH was fitted) that my old boiler (Vaillant heat-only boiler)...
