Discuss Heatslave 18/25 (Oil fired) in the USA area at PlumbersForums.net
CH pump and diverter valve active when there is is no demand. I suspect relay 4 is sticking but don't know how to prove it. If I switch the heating on and off from the programmer it eventually stops.
Reply to Heatslave 18/25 (Oil fired) in the USA area at PlumbersForums.net
The left rear floor corner is highest (the shower pan touches/sits on the floor), sloping down diagonally to the front right corner (lowest). The front right corner shim is 5/8", the left front corner is 3/8" shimmed, with shorter shims under left middle and right rear corner. The pan perimeters...
