Discuss Help please with designing incoming mains size. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sharp Point
Evening peeps,
Ive been asked to carry out the work on a 7/8 bed new build, now usually when i do new builds the incoming main is never to far from the road, so the builder/s usually deal with that. This job is for a private customer, who has literally built the house himself and i must say its fantastic. Every bedroom has a en-suite ( loo, basin and mains thermo shower) there is a master bathroom ( bidet, wc, basin and bath)
The house has block n beam on ground and first floor, 2 bedrooms in the attic, UFH throughout every floor, Unvented hot water, secondary hot water and ground source ( slinky's already installed in his fields)
Right, the new dwelling is 165 metres from the road, right next to the old farmhouse they're living in at the moment. The farmhouse currently has a piddly 20mm old style mdpe supplying water and the pressure is pants, and yes i've done the obvious checks. He has applied for a new connection with anglian water, who have sent out a pdf form via email to fill in, the custard has filled out the majority, but has asked me to help answer some questions, as i've never completed a form before, i'm a little bit stumped........
Is there a possibility you good folk could help? right here goes....
custard has tick yes to a supply larger than 32mm, then they want to know
1) maximum daily demand in m3 a day- total
2) maximum instantaneous demand litres per second - total
3)on site storage- litres
4)Percentage of daily demand supplied via storage- total / domestic
Is there a rule of thumb for number 1, guesstimated number of wc flushes, cooking, bathing?
There is no instantaneous, its stored hot water for number 2
Is this for hot water or cold water in general? number 3
number 4.......not a clue.
Me and the custard have agreed on a 300 litre unvented hot water cyl ( enough to accomodate his self and wife, children when they come home from uni)
Anglian Water recommend 50mm pipe for runs 100 - 800 metres. I suspect the other information is to confirm all new equipment complies with water efficiency regs.
Google Water efficiency in New Builds.
They may also wish to flush, pressure test and possibly chlorinate new main.
Looks like a nice job!
I'm dong a similar property, but I'm way bigger than what your proposing. 300 litres would do three bathroom property, but it's mo good for the other 5!
Why put a system in that will not perform when all bedrooms are occupied?
If you work on a low figure of 20litres a min per bathroom excluding other hot outlets, the hot water will run cold after less than 3 minutes!
I also would be fitting a pump set as you can't guarantee the flow rate needed from the water main.
Booster set and header tank would be best. As Chalked says you want the system to perform to expectations. A 32mm main may not deliver enough for the amount of water you may require.
300 litres was his suggestion as the house will only really ever be home for two people. We both agree that working on the basis of 50/60 litres of hot water per person for two people that 300 would be ample. To have a bigger cylinder sat there losing heat seemed pointless, bearing in mind it's going to be heated by a electrickery gobbling ground source heat pump.
It was mentioned by myself, but there is nowhere to house any tanks and the purchase / maintenance costs, soon put him off. It's a nice pad, but he does seem to be doing it to a budget.
Yes, your quite correct on that, but initial talks between custard and anglian water have resulted in a ' we don't/ won't fit a 63mm connection'
How old is the ground source heatpump ?
Its being designed as we speak by 'Plumb centre's renewable dept' i've no idea on what they're going to pull outta the bag? I've sent all plans via email to them, as i want no comeback if things aren't right.
If its designed correct it will nock spots off oil, lpg and natural gas. 300 litre does seem a little small. What is the road supply pressure
Reply to Help please with designing incoming mains size. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Morning everyone, if anyone could please offer advice on this issue it would help me with a massive issue regarding the water supply in my flat...
Background I have a small one-bedroom flat in the roof space in a victorian house. There are three floors below and each floor has a single...
M
I have a viessman vitodens 222F combi storage boiler on the ground floor. It has 100l capacity inbuilt cylinder which is delivered on mains...
Max Hill
M
Hi everyone just checking if this is right regarding water pressure and combi boiler pressure: Do hot and cold water always vary in pressure such...
Hi Everyone, For those who like a long read but I could rally do with some advice. Might be a bit long this. For background. A...
