Discuss Help please with designing incoming mains size. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I can understand doing a house like that on a budget and saying they will only be using the house mostly for two people.
I beggars the question, why have 8 bedrooms with en- suites??
If its designed correct it will nock spots off oil, lpg and natural gas. 300 litre does seem a little small. What is the road supply pressure
I/ He hopes so, we've heard so many horror stories. Standing pressure is 2.2, dynamic is 1.3 and has a flow rate from existing outside tap straight off old farmhouse incoming mains of 11 l/m
I know, i know..... we've discussed things at length and this is the compromise, it was hard enough to convince him to get a new cold mains connection, he wanted to just use the piddly old mdpe supply.
Right been doing some research on tinternet, seems an average person uses about 150 litres a day......does that sound about right?
quick back of a beermat calcs,
8 x 150 = 1200 litres = 1.2 m3 water a day, when full occupancy.
What electric supply has the building got?
Until 'Plumb centre' pull they're finger out and come back with the heat loss calcs/ heating load, then we can decide whether it'll need a 3 phase supply.....if thats what your meaning my friend.
Yes mate that is exactly what I mean. It will need 3 phase without a doubt . if there is concern over cost for a water main, tell him to get ready for the electricity supply
I think he's sort of prepared for that........i think.
If you have a pump room, 2no 50 gallon tanks break tanks, 1" ball valve, Grundfos booster pump, here: CM, CME BOOSTER | Grundfos and ususal additional products, check valves, associated valves, etc, pipe sized accordingly.
Done this on many hotels and bespoke projects! Works every time when there is low pressure and bad flow rate.
Thanks for that 'Cardiff plumber' from your experience, what height do the cwsc have to be above the pumps?
Reply to Help please with designing incoming mains size. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Morning everyone, if anyone could please offer advice on this issue it would help me with a massive issue regarding the water supply in my flat...
Background I have a small one-bedroom flat in the roof space in a victorian house. There are three floors below and each floor has a single...
M
I have a viessman vitodens 222F combi storage boiler on the ground floor. It has 100l capacity inbuilt cylinder which is delivered on mains...
Max Hill
M
Hi everyone just checking if this is right regarding water pressure and combi boiler pressure: Do hot and cold water always vary in pressure such...
Hi Everyone, For those who like a long read but I could rally do with some advice. Might be a bit long this. For background. A...
