Discuss ideal drill bit size for 15mm pipes in the DIY Plumbing Forum area at PlumbersForums.net
F
Frank13
I am tiling a shower wall and need to drill holes for 15mm pipes that will go to a thermostatic valve, what size of drill bit for the holes is best?
Depends on how spot on with your measurements you are 16mm but most use a 18-20mm
16mm?! Hope you're all doing your own second fix.
There really is no excuse to tile it so tight when easy fix kit cover plates are 65mm and the talon pipe shrouds are 55mm. There's nothing worse than having to chip the tiles out because the tiler moved the pipe to fit his hole that has zero tolerance and in the incorrect spot
Also a 16mm hole won't go over a soldered cap end
No actually a cowboy builder tiled my daughters wall and left the radiator pipes hidden in the stud wall. I had to cut the board from the other side to find the pipes and drill the tiles to mount the radiator as he boxed everything in and no sign of the pipes.
Regards,
Dave
While I generally agree with your comment, I would say that having half a tile missing and a hole all around the pipe you can stick your finger through and having to patch in a new tile is also pretty bad. lol
Reply to ideal drill bit size for 15mm pipes in the DIY Plumbing Forum area at PlumbersForums.net
Pipes for thermostat shower have been fitted at different heights. Any way of rectifying without ripping all tiles. So for clarity 15mm pipes...
Hello guys, an easy one: I recently had to drill through two outside walls to run 15mm pipes for a shower and sink. The holes are neat enough but...
I recently had a plumber come over to look at a badly leaking shower head. As best I can recall, he described the problem as a crack in the bridge...
hi all i need some help and advice i am tiling around 2 shower pipe fittings. as the measurements were intricate i was practicing on off cuts...
1K
