Discuss lead soil pipe from WC to CI stack in the Plumbing Jobs | The Job-board area at PlumbersForums.net
mjt
HI
I have been asked to remove a lead soil pipe which enters a CI stack as it is leaking at the joint with the CI branch - what would be the best way to do this in your respected opinion?
Once removed i presume there is a multikwik fitting that would fit into the branch so that i could run plastic from the WC?
i've not been asked to do this before so i would appreciate your comments
thanks
if the lead is burst where it goes into the stack you will have to remove it completely, once done you will be able to fit pvc pipe into the faucet of the CI and seal it properly then fit a multikwik onto the pan and join them together, if the lead is burst away from the stack you can cut the lead and fit an extention multikwik inside the lead (the easier option) and a multikwik onto the pan
thanks for your reply
it has gone where it has goes into the stack as the guy has put some sort of foam sealant around the joint.
is the lead straight forward to remove?
It will be joined to a brass ferrule as it enters the collar. Cut the lead off then bend the ferrule inwards at a few places and lift it out.
Easiest way to connect the new pvc pipe to the cast collar is with one of these
OSMA - Plumbing & Drainage Products - Connectors - Soil,WC,soil and waste,waste pipe,waste and traps,plastic soil pipe,soil and vent,toilet,aav.
Only Osma do them AFAIK
Or you can just caulk it in with one of these types
made by just about all
to get the ferrule out of the cast youll need to either heat it up and run the lead out or cut it flush to the collar and then cut internally in two places to split the ferule and pick it out
mostly to join i would just push 4 inch into the cast wedge some paper round inside and use a strong mixed cement joint
HI
I have been and done this job yesterday and successfully replaced the pipe in question - once i removed whatever was hloding the lead in the cast iron socket (it was all quite soft and mushy) the lead just pulled out - thanks for your advice it really helped.
MJT
It is called rope yarn and it will have rotted a bit over the years
Reply to lead soil pipe from WC to CI stack in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down...
