Discuss Look seat screws just spin, no access to underneath. in the USA area at PlumbersForums.net
I want to change over a toilet seat but have come across an issue.
The screws holding the connection to the pan simply rotate, either left or right. Because of the pan design and location - I cannot access the back to see what's happening under the fitting.
Image0 - the underside, no access to under the fitting
image1 - the fitting connecting to the seat
Image2 - the fitting connecting to the pan.
I can get the fitting to loosen slightly (the seat shifts from side to side quite often). I had thought about a hacksaw blade under the fitting but this feels a bit final. I suspect I either a) live with the existing seat, b) cut off the fittings and see what I can do with what I find underneath c) new pan fitted that gives me access to avoid this in the future.
any tips, insight gratefully received.
Try lifting the seat so there’s tension and then unscrew the screws
Reply to Look seat screws just spin, no access to underneath. in the USA area at PlumbersForums.net
I tried to install a new toilet seat and I’m stuck in a process where I couldn’t loosen or tighten the screw. I also tried rotating the screw in both ways but that’s just a endless process and it wouldn’t come off. It’s a in wall built toilet so I could only stick my hand underneath a bit and...
Hi folks, sorry to have to post this but we got a new bathroom a few months ago and the toilet seat was loose at one side. The cistern is integrated and the seat is top-fixing. I assumed it was quick release but couldn't find a button to push, there are no little grommit hidden screws or...
1K
From what I have read online, the ideal standard toilet seat does not have a release button, i am supposed to just pull the seat off to access the fixing to tighten screw to stop wobbling seat. Is that correct? When i pull it nothing happens
2K
Hi, fitting a back to wall toilet in a small cloakroom. The soil pipe is a vertical clay pipe about 20cm from the wall and so I will have to build boxing to be able to fit the toilet to the wall (this will hold the concealed cistern). I bought a flexi 90deg pan connector for back-to-wall...
1K
Deleted member 120897
Hi all Relatively inexperienced homeowner here. Apologies in advance if I get any terminology wrong. Today I noticed some limescale accumulation on/around the grout between the floor tiles next to my toilet. I realised that the grout line right next to the toilet was in fact wet to the touch...
1K
