Discuss Mains feed and vent pipe on vented system in the USA area at PlumbersForums.net
Matt0029
I have a boiler to swap on a vented system. The open vent was presently attached straight to the boiler. And the cold feed is tee'd in to the hot water return near the coil. When I install the new boiler (it's staying vented). Would I be best off changing the cold fill postion I will obviously need to alter the open vent as it did originally tee straight off the boiler.
With a view to possibly changing it to what it states in the new boiler manufactors instructions.
Sounds like it was gravity hot water
and yep either need to adjust one or convert to sealed
It’s prob been semi converted
Thanks so if I keep vented I should really change the cold feed postion? I need to change the vent anyway. Can I ask the reason for the inverted cold? Is it to stop water pumping back in to the head tank? Thanks
Anti gravity loop, stops gravity flow back upto the tank
Been looking through some of my old level 3 books. That shows the cold feed to the system tee'd in to the primary return on a gravity hot water system same. Was this done to try and make the primarys circulate more?
Reply to Mains feed and vent pipe on vented system in the USA area at PlumbersForums.net
Hi, I'm new to the forum and just some background on myself. I have 4 years experience as a plumber but haven't worked in the trade in 15 years. I...
Hi guys Is it normal for the cold feed pipe from the f&e tank to be combined with the open vent? The cold feed connects to a 22mm tee one end is...
1K
… praying to the plumbing God, Bob Pictures and layout details attached, so be patient. 21 year old oil fired system in pretty good nick. I...
1K
Hi, I am replacing our 11 year old boiler (due to H.Ex. leak) with a new one. This is in a "sealed" system with red expansion vessel in airig...
I recently took off an end stop on the vent/expansion pipe over the heating header tank. I now know why it was capped off. When the 2 way valve...
2K
