Discuss Meter Test Nipple in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
amy
Hi Guys,
Just had a friend ring me with a broken test nipple in the meter,ie, the screw has snapped and can't remove the broken threaded part of the screw.
He tried all local suppliers and was looking to buy the whole unit,ie the part that the screw fits into and replace both components. He could only find 1/8th inch and this is too large.
I thought I had a spare but that turned out to be a 1/8th inch test nipple .
I suppose my question is what size are we looking for and can you get these test nipples for meters,if so where from.
Or, do we have to ring transco to let them fix.
Like I said I had a test nipple in my kit (ordered nipple from BES a while ago ) to cater for this eventuality and am pleased this size issue has been brought to my attention.
Friend just rang me up to say he managed to drill the broken part of screw out with a 3mm drill bit, so thats one way to fix but still interested if we can get spares.
Thx, amy.
Hi Guys,
I will update my own thread here.
My friend has just informed me of the outcome about the test nipple.
He managed to drill out the old screw and replace but had the slightest of bubbles appearing on LDF test, couple rounds of gas tape sorted this out.
We havn't come across test nipples with gas tape on, has anyone else?.
He had earlier rang transco and they attended and informed him that they usually replace the meter in these circumstances.
The test nipple is not available from stockists but the screw is.
There is a new meter coming out that will be an all in one unit so this kind of problem will not occur in years to come.
amy.
this commonly happens to the beige coloured meter i cant remember the thread size but have seen some with gas tape on so would not worry,transco will sort it
Yes new meter, happens frequently.
Don't bodge it, call the emergency number and get it fixed properly. I've never known them charge anyone for a damaged test point.
get your grips on it and use a very large lump hammer to 'help' it tighten
ps. just kiddin before anyone slates me, lol
Classic over tightening. Why do they put a hexagon nut on them, for a spanner? A screw driver is plenty good enough.
This happened to me once on a u6 meter with very little force the screw just snapped. I always have a couple of spare screws in my tool box but it did take some racking of the brains to get the rest of the screw out i really didnt want to damage the thread as it was not one that screwed out but threaded into the meter itself. I drilled a 3mm hole though the screw then using the same drill bit i smeared it with super glue and after letting it dry the screw cracked out using a set of grips on the drill bit. This method worked but if it ever happens again i will phone transco.
phone gas supplier ,transco ,scottish gas networks they come and repair free.
or go to pts and buy them
Reply to Meter Test Nipple in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Locked
Hi, newbie here. Just wondering if anyone knows of a stockist in the newcastle area where I can get spare meter test point screws from? I can see...
13K
11K
migoplumber
M
L
  • Locked
Hello. I returned home yesterday to find an Anglian Water engineer had put a card through our door explaining that due to a substantial increase...
31K
G4WIL
G
H
  • Locked
Hello All, first post here and I really hope you can help me:o. I’m no stranger to tools and meters, but I have no idea about household plumbing...
3K
PlumbBobBob
  • Locked
Dear ladies and gentlemen, I am a tenant in rented house. The landlord has not had a safety check 2 years and the last one was by his friend who...
7K
POWDERPUFF
