Discuss Pan connector advise please in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
After some advise please. Currently in the process or replacing a toilet. I was hoping to use the existing pan connector as it seems completely seized in the soil pipe collar. I'm worried I'll break the collar if I try and twist thr connector too hard. The front seal on the existing pan connector has perished and broken off on removal of the toilet.
What would be the best cause of action? Try and carefully cut the connector out the collar with a multi tool, or is it possible to get a replacement front seal and plastic clip?
Many thanks
It’s glued in needs cutting lower then depending on the toilet you might need a mcalpine con 8 / 8e
Wood saw horizontally follow the top of the collar
The new pan connector will just push into what’s left you might need to trim the height of the pan connector depending on the height of the toilet but that’s fine
Reply to Pan connector advise please in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I had a plumber in to replace my old pan connector as it was leaking due to the wax deteriorating. Now when this toilet clogs up (which is a...
Hi, fitting a back to wall toilet in a small cloakroom. The soil pipe is a vertical clay pipe about 20cm from the wall and so I will have to build...
2K
Deleted member 120897
Hi all, We've got a toilet that's been leaking due to a faulty seal with the pan connector. We've had a plumber in to replace the pan connector...
Installing a new toilet in a small cloakroom. The previous toilet was connected to the waste through a 5" plastic fitting that is attached...
Hi guys, I’ve got a close coupled toilet wher the waste come out of the back of the toilet then it’s a 90 degree bend to the right where it goes...
