Discuss Pipes attached to rafters in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
C
CluelessPunter
We're having the loft converted at the front of our house, and the plumber has routed the new water and central heating pipes via the rafters in the back loft (which isn't being converted). He's wrapped some insulation (looks like TopSleeve) round them and assures me it'll be fine. I'm worried the pipes will freeze in winter. Should I ask him to re-route the pipes to underneath the loft insulation? Or am I worrying unnecessarily? I live in London.
Best to insulate them I’m guessing there too close so might be worth building an insulated boxing
Any heated or cold water pipework outside your living space should be insulated individually you definitely shouldn't insulate hot and cold pipework together . Kop
They’re separately insulated with foam (not TopSleeve as I mentioned before - that’s somewhere else). So nothing to worry about, then?
I would want thicker insulation on them tbh 25mm should be fine
Reply to Pipes attached to rafters in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi I recently did some pipe insulating in my loft. The only two I didn't do were the vent pipes. Not sure if that is the right term for them...
I would like some guidance regarding the Worcester CDi 29 Classic boiler. According to the manual it has a holiday mode and frost protection mode...
Hi All, I have an unvented cylinder system up in my loft (tank, boiler & piping etc). I have insulated the loft roof (so kinsgpan in the...
5K
Hi all, just joined the forum. I am not a plumber but a handyman in my spare time for local customers for various jobs within my skillbase. I...
Hi there, thanks for your time to look at this record long post!! I work on the operational management side or a small building contracting firm...
