Discuss Push-fit for toilet run in the Plumbing Jobs | The Job-board area at PlumbersForums.net
E
EdFromGreenwich
Hi, I have a "horizontal" run of 4m from the toilet to the stack with a long bend and 2 tees a tees along the way. Can I use push-fit connection pipes (Floplast) or do I need to use solvent weld? Many thanks. Ed
Yes you can use either
But depending on what your doing building control might need to be notified
Reply to Push-fit for toilet run in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
Hi all Noticed bad smell in my drain out side put my hand down and it unclogged it for now however I checked my sewer drain and after flushing my...
