Discuss Radiator TRV valve adapter in the USA area at PlumbersForums.net
Hi
I am trying to install a radiator smart thermostat but the thread on the radiator connectors valve doesnt fit. (see picture) The valve came with adapters but they are not good. Any suggestion on a adapter which would fit the smart thermostat?
Reply to Radiator TRV valve adapter in the USA area at PlumbersForums.net
Hi I am trying to fit a Hive Radiator valve into my existing TRV valve body to make them automatic so have bought a Hive valve to try it out. I...
Hi all, Looking for some advice please. Got a building, all one level with 7 radiators. 3 individual ones in separate rooms then 4 radiators...
Hi we have a Alpha 2 15-60-130 central heating pump fitted. We need a bit more heat from 12 rads. I’m confused about the settings as the Auto...
I am trying to install a new single vertical radiator and need to know if matters if the thermostatic valve is connected to the flow or return pipes.
Hi, I need to remove some radiators for redecorating and went to try and shut off the valves either side of my rad. I have TRV on one side and on...
