Discuss Removing a stubborn tap valve? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
Annnie
Hi folks
I'm trying to remove the valves of my bath mixer taps (they are against the wall). I've tried various DIY spanners, pliers, WD40 etc but it just wont budge.
So are there any tricks or special tools for getting the valve out?
Sorry photo is sideways :)
Thanks Tonycane but it just slips off. Its not 'rounded' but its just not budging.:disappointed:
16mm then if that won't fit try an imperial/ adjustable movie
sometimes quicker to whip the tap off and lock it in a vice, then use body to unscrew it.
hit it with a blow torch and a deepthroat socket!
Deep socket if that fails my trusty mole grips not let me down yet
can't do that redraw (remove the taps etc) . They are fitted against a wall - see photo. If I could remove the taps Id probably just renew them.
They'll come off easy enough if you had used the right spanner. Must be tight fit or it will slip. Those modern tap works are an O ring seal but still are metal to metal tight fit.
Pump plier grips will do and have good leverage, but are rough on the brass.
The valves should come out relatively easy, luckily you have a deck mixer which keeps the bath tap solid allowing more leverage on the valves! I would use my large 12" Bahco spanner.
http://youtu.be/TGF39ReBrj0
Cheers Tony, but I live in Warrington.
surely there must be someone on here that is local to you. you could post it on the job section. [DLMURL]http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/[/DLMURL]
Sometimes if they are really stubborn, try tightening first then undoing. Worked for me a few times
Notice the video stopped and restarted at the critical moment. The slipping spanner and swearing was cut out. He then went to the van and got a socket to loosen it then pretended
it may be redraw if the deapthroats didnt work¬¬¬pmsl
Crowfoot spanner then a back nut spanner if not junior hacksaw if they're plastic
Reply to Removing a stubborn tap valve? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes a squeak noise as I turn it on or off, left tap is 100% perfect and noiseless. This grohe tap is like one unit, so no screw notch or way I can remove...
