Discuss Removing a stubborn tap valve? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
The valves should come out relatively easy, luckily you have a deck mixer which keeps the bath tap solid allowing more leverage on the valves! I would use my large 12" Bahco spanner.
http://youtu.be/TGF39ReBrj0
Notice the video stopped and restarted at the critical moment. The slipping spanner and swearing was cut out. He then went to the van and got a socket to loosen it then pretended
can't do that redraw (remove the taps etc) . They are fitted against a wall - see photo. If I could remove the taps Id probably just renew them.
it may be redraw if the deapthroats didnt work¬¬¬pmsl
Crowfoot spanner then a back nut spanner if not junior hacksaw if they're plastic
Reply to Removing a stubborn tap valve? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I am trying to replace my bathroom tap with a new one, I am trying to remove the existing rusty flexible tap connectors from this bit of 22mm...
I’m trying to replace a cartridge on a Grohe mixer tap but I can’t get beyond second stage! I have removed the grub screw,but cannot lift off the...
2K
I am trying to replace the cartridge for a waterfall tap (mixer mono) for the bathroom sink, I have run into a problem whereby I cannot remove the...
Hi all, trying to replace a Victorian mixer tap head for bath as old one getting stiff. I've got cap off and taken screw out however can't remove...
Hi All, I have this monobloc basin mixer tap in my bathroom. It was installed 11 years ago, but the hot valve has started to drip from the top...
