Discuss Removing broken 22mm waste pipe from elbow joint in the USA area at PlumbersForums.net
Hi All,
I'm about to install a new Macerator unit in a downstairs cloakroom and was planning on using the waste pipe from the previous unit. The problem is the old UPVC 22mm has broken off inside the elbow joint that goes into the wall.
Does anyone know the best way to remove the broken part of the 22mm pipe without damaging the existing elbow joint? I'd rather not have to dig out the wall to replace the whole section.
Pic attached to show how the pipe has broken.
Thanks in advance for any advice!
Dan
1. Does the new one discharge through 22mm as many don`t.
2. Hot air gun has been known to work.
3. If it broke very easily then I advise replacing the pipe run completly.
Looks like 32mm to me
Thanks for the suggestions all, in the end I heated up a 19mm socket wrench bit with a heat gun, held it inside the elbow joint for a minute which enabled me to pull the old broken pipe out of the joint with some needle pliers.
Worked really well and has left a clean surface for me to attach a new piece of 22mm pipe into the joint!
Reply to Removing broken 22mm waste pipe from elbow joint in the USA area at PlumbersForums.net
Our boiler is in the loft and I encountered a leak in a roof above our side extension store room which has transpired to be from the boiler...
Hi, Short version: I have about 4" of pipe sticking out of a concrete floor in a cupboard. It makes a 45-degree bend as it exists (bent, not with...
I'm installing a waste pump in wet zone area(ground floor concrete) Waste pump has 22mm feeds which I would normally connect to soil pipe with...
2K
N
Hi, a plumber has been out to my rental property as my tenant reported a blockage causing water to flow back from the washing machine into the...
2K
