Discuss replacing diverter valve without removing diverter housing? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
W
wesley
hi guys
i have a rubbish boiler yep you guess it correct. ISAR HE30. i got it free via warmfront.
anyway. 3 years ago, the problem started when the hot water sent to radiators. plumber came and replaced the diverter valve/actuator and charged me £300 for everything.
last year the boiler stopped working and displayed error message (cant remember what was the message). i researched the error message and it was the faulty PCB so i decided to replace it myself. bought new one and replaced it myself. it was dead easy.
last night the hot water is sending to radiators again grrrr. but after switch off and on the boilder. its fine now. i think the diverter valve is sticnking and will fail very soon. i look up the manual and it looks very easy to replace the diverter valve but the question is do i have take the diverter housing out before replace the diverter valve cartridge (part no 174200 or 173967, will check the colour of box head when i get home). ? will it damage the gasket if i need to take the housing out?
or can i just remove the actutor and replace the diverter valve cartridge?
oblviously i'll drain the water first
cheers
You need to get someone in. Don't mess with it yourself as there are other things that need looking at to make sure that the boiler is operating safely because these boilers had a problem on them.
If you didn't like the heating engineer you used last time then try someone else recommended to you or post your location up on here and some one may be able to help you.
hi guys
cheers
please read the forum rules. You will not get any advice on here relating to gas appliances. This is to protect YOU!
for a start, you mention to replace this part looks easy. But to need advice, means it not as easy as first thought.
if you do go ahead and replace this "easy" part. Ask yourself, how do I check afterwards for gas tightness and correct boiler function and combustion?
The answer is, you can't and don't know how.
dont put yourself and family in danger to save a few pounds.
Reply to replacing diverter valve without removing diverter housing? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello all, I have a WorcesterBosch Greenstar 42CDi classic combi, which is providing DHW fine, but not heating. Was working fine in spring...
Hi, this is my first post.. hoping it's an easy one that someone can help me with. I've got a standard system (not a Combi.. just a Bosch gas...
2K
My kitchen radiator is filling with hot water despite my TRV being set to 0. It's blazing at maximum. This goes for the rad when I try two...
2K
5K
Current boiler Worcester Greenstar 30CDi installed Aug 2011. Started showing error EA. Initially a rest made it work again but last Thursday it...
