Discuss Shock arrestors in the Plumbing Jobs | The Job-board area at PlumbersForums.net
kozak1968
Does anyone know if there is a calculation for fitting a shock arrestor to the incoming main to a boiler. All I can find is that a shock arrestor/ expansion should be fitted if a back flow prevention device is fitted to the main, ie a double check valve or water meter.There is nothing about the minimum length of pipe or volume of water required to take up the expansion from a combi boiler. I'm sure someone will point me in the right direction.... Thanks.
if the manufacturer advices one if pressure is high or non return valve fitted then you fit it, or as you say ... nil warranty
Intriguing question, those of us around before water meters are inclined to think of a supply through open stopcock all the way back to the water tower. In reality an anti backflow device is usually fitted at boundary even for households who opt for a non meter account.
The volume effect is offset to some degree by the thermal expansion of the pipes through which the water flows and a diversity principle, similar to electrics, may be appropriate.
Meanwhile, one is better than none. I suspect many appliance is protected by a dripping tap.
Without wanting to limit discussion. I would also consider an unvented DHW cylinder may offer additional protection.
I spec them on every combi regardless of what the MI say. For the sake of a small cost it saves any potential damage in the future. Plus if you went to the extent of figuring it out (if even realistically possible) , who is to say it wouldnt be modified in a years time by some other plumbing works.
Reply to Shock arrestors in the Plumbing Jobs | The Job-board area at PlumbersForums.net
