Discuss sievert powerjet- propane canister help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
i recently aqquired a sivert powerjet nozzle for soldering but cant get the prpoane canister a bought to fit does it need an adapter or do some not fit?
Sievert. Now there is a name from the past. Used to make top quality blowlamps..........paraffin:)
Didn't know they were still going.
Thats me learned another thing.
have you got the proper primus 2000 cylinder, theyre £35 ish then cheap to refill. get them online or at most mercheants
Just noticed this post. There are 2 versions of powerjet burner. One for the refillable 2000 canister and one for the disposable. They are not interchangeable.
I have been after an adapter to go from the 2000 to disposable cylinder but as far as I am aware there isn't one. It's a great burner though.
I think Sievert merged with Primus or something. The Powerjet burner used to branded Primus and now it is Sievert.
Theres some adaptors availbale here..
[DLMURL="http://www.monument-tools.com/gasex.htm"]Tools, Plumbing Tools, Drain Cleaning, Plumbing Equipment, Drain Cleaning Equipment, Herramientas para Instalacin de Calefacciones y Fontanera, Rohrwerkzeuge[/DLMURL]
Do not mis pronounce the gasex thing some will think you are a queen!
I think you need the refillable primus cartridge for it. They actually work out cheaper in the long run than the disposables. I used to have one until somebody nicked it and it was a good torch. Many merchants do them, and also companies who do welding gases always stock them.
Reply to sievert powerjet- propane canister help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Sticky
We have 2 brand new cordless, battery powered press tools in stock, and flying off the shelves. Our TekTools TZ1930 & TZ1550 are packed with...
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
Fitted unvented hotwater cylinder building control looking forms signed it off job was in england i am qualified northern ireland send out a form...
