Discuss storing flux gas and solder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Stanley fatmax open tote which was by tool bag before I changed to different one
I use a normal size tool box, lamp fits in bottom without taking apart with solder, flux, cutters, bending guides etc and a load of 15 &22mm fittings and the pull out tray is full of 8/10mm fittings
One of the guys on my firm has one of these:
Stanley 24" Tool Tote & Organiser | Tool Totes | NoLinkingToThis
Fits his bottle, flux and solder, loctite, jet blue etc quite nicely plus with the top organiser bit he has a selection of enfeed fittings olives and that :D
Keep meaning to get myself one
This is my cheap and nasty..
Thats what I use as well. All soldring kit and fire extinguisher in the bottom and more common endfeed fittings in the top.
I just had to replace my blow lamp and it was cheaper to buy with a hot bag and 2 bottles of gas than just the lamp alone so might start using that instead.
Reply to storing flux gas and solder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All, I hope you are doing well. I have this 3.25mm lead-free grade 99c solder wire. I know that the good practice to bend the wire before...
I'm a complete notice and I working on my heatings motorised valves on my S plan system. I was modifying the system to add an arrester. Long story...
Is there any clause that says I cant remove the rubber rind on a viega fitting and solder it on my domestic gas installation? Thanks
Peter N
Hi, Short version: I have about 4" of pipe sticking out of a concrete floor in a cupboard. It makes a 45-degree bend as it exists (bent, not with...
1K
