Discuss The radiator doesn't heat after i've added a plastic pipe to it in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
Andrii
Hi everyone!
I need you advice to solve a problem with my central heating system .
I am not a plumber - and sorry for silly questions .
I bought a 15 meter plastic pipe/tube - and laid it down under a laminate floor firstly .
After that - i disconnected the hot water flow from the nearby radiator and connected to the plastic pipe - and the another end of the pipe I brought it back to radiator .
Basically - shouldn't be any problems - as what i did is -i just made the water flow pipe longer (under the floor)
I hopped i can get a warmer floor :) - but the plastic pipe heats ok only half of its length - and at the other end where is connected to radiator is only warm a bit - its not hot :((
In other words - water doesnt circulate through the radiator ....
Please advice my - any chances i can fix the problem - or shall i remove the plastic pipe ?
Thank you very much
jobs like this should be left to a professional. When underfloor heating is installed it is regulated to a certain temprature, your new bit of pipe won't be. Turn all rads off in the house bar the one not working. This will fix it and most likely make alot of the valves you turn off leak in the process so check them if they are not trv's. If they leak then you need to call someone in as you obviously don't know what you are doing. Sorry to saound funny, just trying to help
forgot to add the heating will need to be on. Once rad is hot turn all others back on, you may have an airlock or issues with sludge
We have 13 radiators
I will try tomorrow - to turn them of - apart the one does'nt heat
and will run the system for about 15 20 min ?!
I am a bit worried not to make it worse ...
ive just looked at the picture. Are you planning to lay laminate floor over the pipe like that?
nope - its an old photo - the pipe is in 15 mm concrete already - and after that - i will put the laminate ?!
I know is very unprofessional
I hope at least it will heat up :)
that will be a utility room - and is quite a cold one right now ...
Reply to The radiator doesn't heat after i've added a plastic pipe to it in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Our house was built in 2007 and we are the second family to live here - moving in in 2017. The central heating has been working fine - although...
L
Hello Please could I have some advice. I recently had an new air source pump and hot water tank system installed. The pipes to the radiators...
Hi, Sorry if question already answered in previous posts, but I can't find a solution to the below: We recently moved house to a new home that...
I have a heating system comprised of skirting radiators that form part of a loop from the boiler, round the house and back. Some rooms get...
