Discuss Tool to make exisitng hole in stack bigger. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
armyash
Subscribed
Hi
Boss phoned me today and he asked me to take him a 25mm hole cutter to put in an adaptor to the stack but i was miles away and not finished on my job so when i did get there he said he doesn't need it as he had used another tool to do it.
It was an exisiting hole that he had to make bigger.
It sounded unusual and he didn't know what it was called, he found it on a job. Sounds like it was a cone shaped tool with 2 'spikes' (for want of a better word) on it. I assume he used it in a drill.
I didn't get a chance to see it unfortunately, i forgot as we had more important things to worry about.
Anyway apologies for the ambiguous post but any ideas of what this could be I would be grateful as it sounds like a handy tool to have.
If not can anyone tell me a tool that would do the same job please lol.
Not a file or rasp :p
For use on soft materials and vibrate in your hand like hell unless you get the speed & applied pressure just right.
Depends what your drilling but tray there alright for the limited use they get.
so long as you don't get fancy clip in hole saws you can double them up if you've miss drilled a whole. So if you use a standard arbor where the holes aw threads on put your bigger size on first then the size you've just drilled inside that and use that as your pilot bit.
or if you've a strong grip and you can afford to risk leaving a scratch get the size holesaw you want and get the drill spinning and roll it into position using the shape of the existing hole as either your top or bottom of the new hole. Be warned though that is a rough way of doing it and you will slip at least once
Not exactly the H&S way of doing it but you can guide a hole saw in with a gloved hand on the right hand edge of the saw (it will rotate into your glove which keeps it in place). Make sure your hand is well behind the teeth though or it might hurt!!
Reply to Tool to make exisitng hole in stack bigger. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, We've got a toilet that's been leaking due to a faulty seal with the pan connector. We've had a plumber in to replace the pan connector...
Hi, We recently moved into a new rental property and have had issues with the heating. The house has a Baxi boiler, and when we moved in it...
The other day I tried flushing one of the toilets in our house, but the handle went straight down and I heard the sound of plastic breaking. Part...
2K
5K
Hello, I hope I post this in the right section. I bought a house couple of months ago. There was an old, broken back boiler installed in the...
2K
