Discuss Water lying in base of shower tray in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
gordmar
Whilst checking drain hole in shower tray, I noticed that there is a good few inches of water lying in the base.
Excuse my ignorance, but is this normal or should this water have drained away.
Any advice would be appreciated.
lying in the shower tray, drained away.
lying in the trap exactly as it should be it stops smells coming back up.
yep thats the whole reason for a trap to stop the smells from the sewage system coming up as gas is lighter than water
and its a couple of inches as water evaporates!
sleep easy tonight
sleep easy tonight
Thanks very much, mind eased a bit now
cheers.
Reply to Water lying in base of shower tray in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I've got an issue with the shower tray not being totally flat. As you can see from the photos, it is about 7mm out at one side. It's leaning...
Do you recognise this shower drain rubber seal? I have searched the web and common plumbing spares suppliers but I cannot find which it is. It...
Hi, I need some help on this shower drain installation. I’m about to install a corner shower kit in my basement bathroom. But I just found out the...
Hi all. Shower is leaking into downstairs when water is being aimed at wall . All sealant has been redone on outside and between shower tray and...
Void under shower former My recently installed solid resin shower tray / wet room former has around 4mm flex across a dinner plate sized area in...
