Discuss Worried customer.. please help in the USA area at PlumbersForums.net
advice please... would you use screws in a tanked wet room to fix batten to wall to tile ?
help appreciated please, I don’t want problems when it’s all tiled!
I wouldnt but seen plenty that do as long as the screw holes are repaired and tanking patched up should be ok i would have completed the floor tiling before fitting the bottom row of tile on the wall you have some one way some the other ? Kop
Reply to Worried customer.. please help in the USA area at PlumbersForums.net
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
