C
cheapskate
hi
I want to replace my current low-level WC with a smaller close coupled one. The issue shown in the photo is that the current soil pipe is too far out from the back wall (240mm) and would mean that the close coupled pan would sit proud. I have mocked up a couple of ideas but they both rely on a large bend at the start (straight out the back of the new pan, turn right, then right again).
I will box in as tight as possible, so the 2nd is better in that respect, though a lot more work moving the pipe.
Do either of these look like sensible ideas? Or do you have any other suggestions? I am willing to twist the entire soil pipe from the stack so that it enters the bathroom at 45º as shown in the 2nd photo. (All I need to do is support a window in the process....!).
thanks,
hi yes I'm moving the pan to the right in the image. so it will connect at the end of the 'virtual pipes' 🙂
My main issue is seeing if I can have a 90º + 45º bend as close together as that. Of course a combined unit would be better, not sure if they are available. will search
Dont forget if you put in a smaller pan you may end up with your dangly bits in the water
Also consider a swans neck conector. Im sure if you google you will find a pic of one but basicly it looks like a question mark.
Not sure 100% if it will get the pan back far enough but worth a look.
edit:found one KWICKFIT 90" Swan Neck
hi, if you use the swan neck fitting as above and take the pan back as far as you an can you not box in behind the cistern down to the floor, this would be a lot easier and cheaper, but i guess if you are struggling for space you dont have many options. good luck, post a pic when all done please.
